| DwrdSpyrl |
"Fuck Off"
21
13- 03
I posted on Team Integra about a problem I'm having with my car... Thought I might get some input from you guys.
| QUOTE | | I have a 1992 LS automatic. The car recently died on me while I was driving. The car would crank, but wouldn't start. I ended up having to have the car towed, and I had the people at the shop troubleshoot it for me. They told me I had a bad ignition coil and computer. I replaced the ignition coil hoping thats all it would take to fix the problem, but the car still wont start. I put an alan wrench into the spark plug wire to see if I was gettin any spark, but I couldn't get it to arc. I was wonderin if the computer would still prevent me from gettin any spark. If the computer is still a likely problem, I wanted to know what computer I could use to replace mine. I have a PR4-A61, but I haven't been able to find the same one. Thanks in advance guys. |
| ProLiFik |
| QUOTE (chris n @ Oct 13 2005, 12:08 AM) | | so i take it youve eliminated it being a fuel problem? i dont see it being computer related. distributor would be what i would point my finger at. could it be your timing belt is off a tooth or so or stretched? |
i was thinking the distributor also chris. I know when i had a similar prob with my teg i with it not starting when it was warm outside. I Changed the main relay and never had the problem again. Or could be maybe a clogged fuel filter.
 I'll miss you Integra :(--2000 Honda S2000 AEM CAI V2 Factory Optioned Out New Top w/ Glass window 04-05 Wheels 5% Tint all around Berk Test Pipe Megan Track Series Coilovers s2000 UK Alignment
| DwrdSpyrl |
"Fuck Off"
21
13- 03
| QUOTE (chris n @ Oct 13 2005, 12:20 AM) | | also you could probably get a better feel for if you were getting electricity to each plug by actually pulling the plug and seeig if it was arcing across the plug gap. |
yeah thats probably a better idea than trying to get it to arc off of the allan wrench, but from my understanding the method I tried is pretty foolproof. Bein so easy to pull the plug out though, i'll have to give that a shot during the day tomorrow. I'll listen for the fuel pump as well. I'd like to eliminate every other possiblity before I fork out the money for a new computer.
